My Long Awaited Build Take TWO!!! Doing it right the second time.
Boozshey
Tampa
So as most know a clogged cat caused my motor to give out. So in light of having to rebuild it's going to have a built bottom end now.
(List of new parts... Not including all the other stuff I already have)
Engine
4.6L Iron Block
Kellog Cobra Crank
Scat Rods
JE Pistons 8.8:1
ARP fasteners
GT500 Oil Pump, TSS Gears o-ring mod...
Valve Train
Stage 2 Ported Heads
Comp Beehive Springs .550
(After everything is running good)
Comp 127550 Cams
Phase Limiters
Transmission
Spec Aluminum 8 Bolt Flywheel
Spec Stage 3+ Clutch
Wheels/Tires
Jeg Star Wheels:
15x11 Rears
15x4 Fronts
M/T ET Streets 26x15x11
Skinny fronts...
Misc...
AFCO Radiator
Slim Line Fans
Mishimoto Hoses
Pi-Thon Hose Clamps
AVIC x920BT Stereo
Polished all steel hoses, A/C Lines and Alternator
Gutted-Cats with H-pipe
Natural1
all around duguder
Angleton, TX
A clogged converter, has led to the demise of many an engine but way to jump back into it! Looks like you have a pretty good "ACT II."
tmcolegr
It's All About the Build
Central, FL
Bruce are those heads early production 3V heads which use HT design spark plugs or the later production that use the one piece spark plug design?
ZmanM3
The Evil One
Jackson, NJ
Glad to see you back on the way to having a running hotrod.
Liberty911
FLA
Way to keep it going! Any particular reason you opted for the iron block?
Royski
Is it really a common issue of clogged cats killing motors? I have heard of one or two here, but honestly, don't know the story behind what happened in either case.
To the OP, glad to see it's getting put back together, good luck!
Boozshey
Tampa
My Kook's HF Cats had 1000 miles on them. Both sides gave out. I think they are crap!!!
Royski
Sucks, were you running boost, or N/A?
I had a buddy blow an ARH cat through his muffler while revving at the line, guess he lucked out.
