Yes, bov is between the blower and IC, drivers side.... MAF is between IC outlet and TB....BOV has nothing to do with power output there is no issue with the bov. This is exactly how it acts on a blower car and is not hurting anything.
With a centri blower at idle the blower is pushing alot of air already. The maf is blow thru way down stream of the bov, there is no way it is affecting maf signal. The bov doesnt/cant create a vac leak or effect maf signal even if it was able to pull in air from there while it was open. (which it cant becasue the blower is pushing air out of it all the time.)
Your bov is between the blower and intercooler and the maf is between the intercooler and tb correct?
The bov spring pressure needs to based off vac at idle thats it, not at cruise or deccel. You want a spring thats strong enough to close it at idle or be slightly open at idle. If the spring is too stiff the bov wont open properly, no good can ever come by having too stiff of a spring.
What is your vac at idle?
Hot idle it will pull -22hg -23hg
For the bold print...
I believe that is the prob with the fluttering.... I believe the amount of air trying to get out of the BOV at a cruising speed or -24hg -25hg is enough to hold open the BOV.... Honestly, it seems even with a 11 psi spring, the motor has to go as low as -10hg at a crusing speed for the 11 psi spring to over come the compressed air plus -10hg to finally close the BOV.... That meens I having a lag of about -15hg before boost can come on..... That also makes for the "fluttering" noise since the BOV valve is prob open just to much or maybe even half way.... IDK, this shit is new to me.....
