its the factory tab part on the axle..
Ryan
no.... or at least i didnt have to and my car is fine... the swaybar relocation kit is simple to put on.I called steeda and they said you had to have the car on a alignment machine. Is this true?
yep!!!!No alignment is neccesary. Cut the tabs, install the brackets, reattach the bar... Done deal.
i just put the reloc brackets from umi on yesterday and didnt have an issue.Is it true you can't run the sway bar relocation with LCA relocation brackets?
