See. Now you have the perfect opportunity to clean up the grinding marks on your timing cover. I tell ya, when I go to do mine, I'll most likely remove the timing cover and grind it off the car. More work, but at the same time, it will be easier to get that part done.
That is a good idea and also a good time to install billet oil pump gears.
