dimitrik8890
CHECK CHECK
Past couple of weeks, I have been having intermittent starting issues. I will go to start the car and it will just make a loud grinding noise, but the next turn of the key will start it. This was intermittent until yesterday when it would just keep grinding. So i put a new starter in, teeth on the old one looked ok. teeth on flywheel looked ok. First attempt with new starter still grinded. But then started right up. Drove the car here and there today and was fine. Five minutes ago, grinded again but then started. Scared to drive car, I understand the basic concept of the solenoid/ starter. Any input/advice would be greatly appreciated.
I also found a video on youtube of the same problem someone else was having. http://www.youtube.com/watch?v=mM7Rnx3izVs
In the comments he says "it was something wrong with the flywheel not engaging" but no solution. THANKS!!!!!!!
