Boaisy
Dark Knight
Yep, full off.
Carbotech pads
Expect Carbotech pads to get mentioned a few times . . .
Norm
Mark, do you run brake ducts?
If you're running 20x9/20x10's right now a 18x10 w/ a 285 is going to feel like an improvement for sure. I'm running 9.5's with 285's all the way around and with the ST XTA's it riding super neutral and grippy.
If those are DW (hopefully not the DWS) then those are some pretty good tires. A tiny bit more sidewall flex than some others, but also weigh a lot less. They aren't going to handle like a 200TW tire, though.
Went with 275 BFG Sport Comp 2s
I used to run those on my autocross Miata. They are ok for a DD summer tire but they will have very little grip for autox.
This. These are what I run on the street, and they work well there. However, even after one autocross the outer tread blocks looked kind of ragged. The S04's handled the abuse far better. Then the RE-11As I'm now running for autocross/track are yet another step up; they handle that abuse far, far better and have better grip to boot.
On my DD wheels I'm using 255/45-18 and I can attest to how well these tires talk to you on the autox. Yea they weren't as fast as the other guys with RS-3's, RE-11's, Rivals, etc. but I was amazed with how well they would communicate to you. Especially for a 340 DD tire you know.
