yes, for me its just bolt on. Promotion did the machine work on the front cover.
Quick time makes a RM8080 for fords, its the replacement of a cobra (03-04) bellhousing, but just like the regular aluminum bellhousing, the whole transmission is rotated about 6 degrees, which is fine if your shifter is attached to the transmission and you dont have a remote shifter like we do that attaches to the body.
you can see how the holes are shifted on that bell housing. the bell housing i got from pro motion has these holes all lines up so the trans sits upright just like it should so our shifter will not be twisted up. they also use 2 spacers that go between the trans and the bellhousing to give it the correct depth. other than the bellhousing and spacers they machine the front plate for the tr6060 by machining out the inside for the correct size bearing around the input shaft and they also have to machine something for the detent at the very top of that front plate where that big bolt head it at.
I didnt have any issues with installing it other than having to trim down a few spots for my turbo piping.
