For what it's worth I switched to JRi mid season from AST Grand AM spec shocks. I used both during an Optima event as well as autocross and HPDE/test and tunes for Optima road course TT portion.
The AST's had badass valving, easy adjustability with the compression located on the end of the remotes. The low speed ride quality was really impressive right out of the box with only dialing down the compression to make street driving a better than stock affair even with much stiffer spring rates.
Then they started weeping mid way through the season... Then I found a broken shock collar that could've wrecked my car...
From working with Dean Martin at Rehagen I knew of Filip and his company, he came with glowing reviews from Dean which he does not give lightly. I reached out to Filip and purchased his JRi setup, with remotes in the rear.
The outside is made from much nicer/tougher materials and it shows. The adjustments are a bit more difficult and are located on the shocks though, and the low speed damping is a bit harsher at impact. This can likely be dialed out with time and tuning however.
With additional tuning time I had noticeably increased rear traction compared to the AST's and was able to run to -4.0 degrees static camber in the front with Filip's camber slugs. This also gave increased front traction. I am also running the Vorshlag 18x11's on 315 Rival S's all around, Filip worked with me to make sure the rear shock adapters gave me plenty of inboard room to clear the wheel barrel. Filip also stayed over the weekend after SEMA to assist with tuning and strategery, he is a stand up guy who makes and develops a great product.
With these shocks I went out to the Invitational in Vegas and did really well for a low horsepower relatively high weight car and look forward to continuing to develop my car with this coming season.
