This is addressed specifically to answer Norm's question, but it is really directed at everyone.
Springs affect both ride stiffness and roll stiffness. Swaybars (perfect ones with no friction) only affect roll stiffness.
Given this for a target ride behavior, you must adjust the spring rates and rate ratio first. Once you have done this, then you can use swaybars to adjust the total roll stiffness and the roll stiffness distribution to tune the static handling balance.
When this is done on an S197 chassis, if you put the springs on the shocks in the rear, for a given target ride rate, they contribute so much roll stiffness due to their separation distance that when it is time to tune the handling with swaybars, you end up needing tiny bar sizes in the rear that aren't available.
Keeping the rear springs on the axle reduces their roll stiffness contribution, so that the rear swaybar ends up a practical size.
I wouldn't use a roll center height adjustment for tuning the static handling balance since this adjustment is almost completely a transient effect. In an AutoX situation it may end up having nearly the same effect since there is virtually no steady state cornering in an AutoX.
On a semi related note, here is a cool ride behavior video from GM with the worlds cheapest, simplest data logger in action.
https://www.youtube.com/watch?v=1W_J6UhQP6s
