Do you guys know if they would fit ok??
17X10.5 with 44mm offset and 7.5 Backspace
I'm pretty sure you will run in to swaybar issues with a 17 that wide.
I think they would. I have 18X10's though with +45mm offset and they fit fine. I don't know how the 17 inch diameter would effect it though---would the 17 hit the rear sway bar when that wide?
can somebody explain the proper way to measure stuff for wheel fitting. I relocated the sway bar since I use a 15x10 wheels for the track. I found out I am getting the 325' mandh tires as a gift from my sisters. I found these wheels and they are dd black bullits.
Oh, the wheel I run the M&H 325's on a is a 17X9 rim with +36mm offset and they fit perfect, even with the rear lowered 1.5 inches. Like SixtySix mentioned, the 325's run narrow, you don't need a 10 inch rim to run them.
where did you find them? i have yet to see a 17x10 with the correct offset for the s197. this is the closet i could find.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=WLD%2D7881709212&N=700+115&autoview=sku
Bolt circle shows 5 on 4 3/4.
Try these.....
http://www.billetspecialties.com/item.asp?cid=16&scid=251&pid=940&rdir=1
Try these.....
What's our bolt circle size??
I've been asked by several for pictures so this seems like a good place to put them. -Joe
