How many degrees can u put for E85
strong_j
TX^SWAG
Wylie, tx
My car just made 640 hp and 600tq at 19*.
I know with e85 these cars love timing so how much can I really throw at it to get the numbers up??
SherrodMustang
Montgomery, Alabama
I ran my up to 26 degrees with E85 and made the numbers in my sig! The very next run I blew the head gasket!
Seemed to love timing, started very low and it made great gains all the way up.
strong_j
TX^SWAG
Wylie, tx
It starts at 17lbs then goes down to 14lbs. I'm thinking some belt slip is going on.
strong_j
TX^SWAG
Wylie, tx
Hey what's ur numbers?? I'm on tapatalk and can't see sigs.
01yellerCobra
San Diego, CA
You should probably fix the belt slip before adding timing. Your power will go up if you can keep the boost level up throughout the rpm range.
strong_j
TX^SWAG
Wylie, tx
Yea I don't know how. It's the steeda 10 rib kit. With the 19lb pulleys on it.
strong_j
TX^SWAG
Wylie, tx
That's a good question. The car is at the tuners so I can't actually see the car. But he told me the symptoms and that's what I'm assuming.
01yellerCobra
San Diego, CA
I had bad belt slip with a smaller pulley. I would go from 12psi to 5psi in a span of 200rpm. When I took the blower off the belt dust was layered under where the pulley sat.
strong_j
TX^SWAG
Wylie, tx
How did u fix it?? I wish there was a way to make it cog drive or chain drive. My 04 cobra had belt slip and frankly this whole belt stuff is pissing me off. Lol.
ethic1
We put up to 25 in mine....Turbo car...It didnt make much more power past 22 though....It was very hot and heat soaked that day though......It made 670 at 16.5lbs....
01yellerCobra
San Diego, CA
I had to change the belt. I know I still have some because I have the dust. Just not as much. I'm still running the 6 rib set up. One of these days I'll install my 8 rib.
05yellowgt
Dayton, OH
24* and 27psi. Didn't try any higher than that on the dyno. I wish I had the money to put the heads and cams that this beast deserves. Would make at least 120 more rwhp I bet.
Sent from my ADR6400L using Tapatalk
That's interesting. I went up to 23.5 with a Whipple at 15psi but power didn't change much past 21 IIRC.
