tmcolegr
It's All About the Build
Can you run lock outs with VSR cams? Thing is I kinda like knowing the car will pull timing to try to save its ass if need.... Although Im sure thats a fine line too.... Also, what retainers and keepers did you go with or which do you recommend?
Yes you can run lockouts with the VSR cams but you must tell your tuner you have installed either (limiters or lockouts) so he can account for that in the tune.
I am running Comp Cams 26125-24 high load valve springs and 700-24 steel retainers.
