So much for that motor.....
tmcolegr
It's All About the Build
Central, FL
Can you run lock outs with VSR cams? Thing is I kinda like knowing the car will pull timing to try to save its ass if need.... Although Im sure thats a fine line too.... Also, what retainers and keepers did you go with or which do you recommend?
Yes you can run lockouts with the VSR cams but you must tell your tuner you have installed either (limiters or lockouts) so he can account for that in the tune.
I am running Comp Cams 26125-24 high load valve springs and 700-24 steel retainers.
NjsGT
Back in the game....
NJ
Cole do you mind breaking down your entire cam setup with the part #'s? Again, thanx for your help man
tmcolegr
Central, FL
127350 Comp Cams
26125-24 Comp Cams valve springs
700-24 Comp Cams steel retainers
5449 Comp Cams phaser limiters
not trying to high jack your thread (only trying to help). My whole build was thoroughly documented in this thread
I'll be glad to answer any questions you may have
NjsGT
NJ
127350 Comp Cams
No high jacking here man lol. Thanx for the link and your help. Best thing about this hobby is learning new things....
94tbird
4R70W FTMFW
NY/NJ
336ci? out of a 4.6 block? How are oyu achieving this. I thought the max we could get is a 302 if bored and stroked
NjsGT
NJ
.20 over 8 times plus a 3.800 stroke gets you to 336 lol... Thats what your motor is too.... Hey, help me pick cams will ya? lol
NjsGT
NJ
127350 Comp Cams
Cole, can I re-use the stock cam followers going with these cams???? Should I replace them with new OEM?
94tbird
4R70W FTMFW
NY/NJ
i think your math is off.
4.6L is 281 cubes
I have a .020 bore 3.75 Stroke Crank and am 300 Cu in which is just about a 5.0
a 3.8 stroke will put you at 302 cubes.
336 cubes would be GT500 5.4 Territory
As far as cams, BBR stage 2 hands down
NjsGT
NJ
4.6L is 281 cubes
Thinking about those too... I think they require lockouts right?
BTW, I am wrong.... Forgot a 0..... It will be a 305 if it can be bored out.... Honestly, I think the block is done... The det damage is pretty deep...
94tbird
4R70W FTMFW
NY/NJ
0.02 bore, not 0.2 lol
tmcolegr
Central, FL
I reused mine, but they were in excellent condition as the engine was non failed and had less than 10,000 miles on it when it was forged. I did replace all the lash adjusters though.
NjsGT
NJ
You just went with OEM right?
NjsGT
NJ
After looking at the det damage closer, 2 cyclinders have det divets that do apear to be deeper then .010.... Looks like Ill be taking my stock block down instead and have that recondition and built up...... Man, good thing I didnt sell it...
TurboX
Formally Buzz Lightyear
San Anto,Tejas
TurboX
San Anto,Tejas
Just spoke to comp, same part. New number vs old number
Cant believe they are there until 8pm on a Friday
tmcolegr
Central, FL
