torque wrench
jsnyng
Alpharetta, GA
You would multiply the ft/lbs by 12 for inch/lbs, but yes you can do it that way. Example 2 ft/lb = 24 inch/lbs.
Edit: Just re-read what you wrote, and you are correct as well. 96 in/lbs / 12 = 8 ft/lbs.
Huck
Southwest Ohio
OK, thanks!
white05gt
Illinois
Just reember torque wrenches aren't as accurate in the lower ranges, also if it's a click style, make sure you work it a few times before attemting to torque something.
yeah if something is rated in in/lbs odds are its too small to use a ft/lb torque wrench accurately.
Jeepngli
Anti-LS1
NJ
^^Thats true. Going vise versa is fine, but you're way is not as accurate
Side note: What torque wrenches do you guys like? Anyone try this one:
http://www.brownlinemetalworks.com/
Hope I'm not stealing your thread too much
jsnyng
Alpharetta, GA
I got that one last month on sale for $99 shipped. It is a damned fine torque wrench. It is very well built and is nice to look at. It is bigger than what I expected (considerably longer/thicker than my Craftsman). It's also reversible which my Craftsman is not.
jsnyng
Alpharetta, GA
Just checked on the Brownline, and the discount code still works. Put the $150 version in your cart and use "Mustang" (no quotes). It drops the price $51 and gives free shipping.
Powered by Ford
just tried the code and it still works. thanks for the info. hopefully I can order this soon
You can also get it from Amazon for $99.99 with free shipping. I just got one and I am very surprised how well the Brownline Torque Wrench works. However, you really do need to pay attention to the screen or the "beeping" it does not "click" like a standard wrench. Something I had to get used to.
http://www.amazon.com/Brown-Line-BLD0212-Digital-Torque/dp/B0032A60W2
Only thing I wish was it was made in the USA. Sadly it is not.
delz05
Boston, MA
Check the Torque specs of the specific engine you are going to rebuild. Some head bolts are torqued to a rate of 85 ft pounds or higher.
Just completed a Hemi 6.1 rebuild that required a 3 step torque procedure....25ft....40ft... then 1/4 turn on the heads.
The smaller rating is probably a 3/8 drive wrench, the larger is probably a 1/2 drive wrench.
Good to have both sizes, along with an "inch-pounds" wrench
Ampire
3 valve
Maryland
When rebuilding a motor, which torque wrench would be better for the job: 10-75 ft lbs or 25-250 ft lbs?
It really depends on the brand more than the torque wrench range IMO. If they are both of similar quality/brand then I would say pick the wrench for the range that you are torquing, usually this would have a tighter margin of error. Most wrenches are like 5-10%. For doing a motor its also helpful to have a angle meter on hand.
I have a 10-150 ft/lb wrench myself, its an old (like 1960's) snapon torqometer 150. Its a good idea to have two torque wrenches and to test them against each other to make sure they are calibrated.
