On3 turbo build
crmpman2
crmpman2
suffolk, Va
Yea he has 93 available but only runs 100 or higher. But does have a 93 tune just incase he can't get the higher octane
JeremyH
3V Fuel Guru
Virginia Beach
Hes probaly asking because 650-750rwhp with a turbo is easily and safely obtainable with 93 pump gas.
Just got my tracking info for the kit. It'll be here Friday :) also I received my aem wideband already. It comes with a cord that I'll include pics with. Can someone please explain to me how I would set this up with the 9 pin connector?
MindIfISmoke?
Wrecking Crew
Puyallup, WA
Red and black connect to the obvious. I believe the other two are for data logging. I like how they used rj45 connectors for there setup in that other thread. Maybe Jeremy or Lito will chime in on the other two wires. I don't use them because all my tuning is done on the Dyno...
Also my ground uses the same ground as the obd2 plug... I used a fuse tap to pull my power from the passenger side kick panel.
Sent from my DROID RAZR using Tapatalk
crmpman2
crmpman2
suffolk, Va
on3 kit installed with the 06 water setup, doesn't look as good as the 07 but it works for know.
crmpman2
crmpman2
suffolk, Va
Also Before anybody comments on it yes it's pretty ugly under the hood but now he has the power he is going to start working on the look.
crmpman2
crmpman2
suffolk, Va
Sorry was just letting him know what we ran .030
18 llbs of boost with plans for 150 shot
687 rwhp 760 ft llbs of torque.
Tuned by Brent Hughes of DTP
does gap really matter? i still need a damn gapper tool... i really dont wanna pay almost 40 bucks just for that though
JeremyH
3V Fuel Guru
Virginia Beach
Yes you want enough heat for good combustion/power but if the gap is too wide the boost pressure will cause spark blow out.
I had blow out at .032 and went t o .028 to fix it. (at 16psi)
bmaxwell
BÆST
ATX
UUUUUGGGGGGHHHHHH SOOOOOO UUUUUGGGGLLLLYYYYYYYY Haha jk bro. Looks nice to me!
I hahad blow out at .032 and went t o .028 to fix it. (at 16psi)
Damn for some reason I thought it was opposite. I thought I read somewhere that the more power you make with boost the larger the gap but hell I could be wrong as usual lol especially when disagreeing with you Jeremy LOL
some help me!! the fucking transmission will not come off!! all the bolts are out idk wtf the deal is. if you can call me 7706332022
Limetime
Okay thanks guys. Just trying to find out what I can expect out of my 6765 H-cover turbo on E85 with a 8.8:1 engine...
With that setup you will be running those GT500 pumps to the max, i just did mine 2 days ago. On 9.8 PSI i was making 520/520 on a 67mm turbo. And having some bad sparkblow out, corrected it with new plugs gaped at .028 but its still there. maybe less boost and more timing will correct it. Going to try a BAS tomorrow on 9.5psi
