if you adjusted your pinion angle, come in!
rojizostang
i love my cams
san antonio, texas
if you've adjusted your pinion angle, specifically to help eliminate drive shaft vibe....
what were your before and after angles, and what was the result?
i'm going to try this one last thing before i give up on one piece alum drive shafts.
MexGT
Mexico
I bought Adj. UCA and with an Angle finder I measured the angle from the downpart of the pumpkin untill it measured -1.5* (aprox)
rojizostang
i love my cams
san antonio, texas
did it accomplish what you wanted? i'm at +1 at the transmission flange and -2 at the pinion flange, and i've got some vibe. this is after installing 3 different shafts and rebalancing...
scramblr
New Braunfels, Texas
I'm at -1.5* now and have gone through three one piece DS. My latest one is smooth as butter until 120mph, then the car starts shaking bad. I'm looking for a shop right now to check the balance of one of the remaining two DS I have. I guess if I was in the States it wouldn't even bother me...but here, it sucks.
Hawgman
THE fucking bad guy
I am at -2 and have no issues at all that I have noticed
Rangersfan
Atlanta
I dropped down to -2 degrees in hopes of stopping a vibration. It just moved it up to being around 105mph with my 4.10 gears.
Now I have 3.73 gears and an axle exchange driveshaft in the car = no vibration AT ALL up to 125 mph.
rojizostang
i love my cams
san antonio, texas
i'm at +1 in the front and -2 in the back, with 4.10's the vibe is around 80mph. i'd be very happy to move it up to 105. i just bought a set of the steeda adj lca's and i'm going to give it one more try before giving up on the 1 piece shafts....i'm just not sure which what to go with the angle, if it will even help at all.
MexGT
Mexico
I do have vibes at 120+mph.
Though I dont go 120+mph very often, I know I need to fix this.
A John In NJ
Rice Cooker
NJ
WTF?? I don't want a one piece DS after all this... Im always driving at least 80 and over 120 sometimes... Has anyone had a success story about fixing the vibration??
-John
rojizostang
i love my cams
san antonio, texas
-John
a lot of guys here are happy with theirs. but if i could do it again, i wouldn't. i have too much money tied up in it now to not try and make it work.
Rangersfan
Atlanta
-John
Yup, changed mine to a different manufacturer and now no issues.
sevenleaf
I went to pep boys, autozone, and oreilly's none of them have angle finders 2 of the shops didn't even know what the hell a pinion angle was !
Where can i find an angle finder besides online. One that is magnetic and can stick to the car.
don_w
Dyno Numbers - Who Cares?
San Diego, CA
You'd probably have better luck at Lowe's or Home Depot. I know I've seen magnetic base angle finders at Lowes before.
MexGT
Mexico
I had to order mine on ebay because no one here even knew what I was talking about lol
