TPMS for 2009
HellsBells
620/677
SoCal
Couldn't find this exactly so sorry if it's been answered before.
Are the TPMS sensors in the 2009 in the valve stems or on a band around the wheel? I see AmericanMuscle sells the valve stem TPMS sensors for the 07-09 GT, are those the right ones or do I need the band ones?
Also, if I have the band sensors but not the bands, will the tire mounting shop supply the bands as part of the stupid TPMS fee?
Newman
sumidicsayhuh?
Houston
09 should be bands.... You can get the valve stem ones from AM and they will reset fine. A lot of valve stem sensors now are programmable. We use mostly programmable ones at work now.
HellsBells
620/677
SoCal
So if I get a set of the band sensors, are they programmable too or? I was gonna grab the sensors from a forum member and just buy the calibration/training tool from AM.
AnotherS197GT
Serial Valve Dropper
USA
Bands are what came stock. You can get the valve stems though. I have them on my 08. Just need to get the wheels rebalanced if you are replacing bands.
Pappy
WI
Stock they are bands. The AM valve stem ones are aftermarket ones that work just the same as your stockers. I have an 09 and have my stock band sensors in my stock wheels and the AM valve stem sensors in my aftermarket wheels, I can't tell any difference between the two.
Call your shop and see if they would supply bands....
Newman
sumidicsayhuh?
Houston
Well they will work for 07-09 . But yes you should be able to reset them to your vech. But see what year they are from, being that they are battery operated and yes the batteries die . Some times after 2years but have seen some last 10years
HellsBells
620/677
SoCal
Thanks!
bumblebee06
Speed Demon
VA
So if you got new wheels and wanted to keep the same TMPS sensors in the stock wheels you would need new ones. Do you also need the tool to set them?
Newman
sumidicsayhuh?
Houston
Either that or if you have a discount tire near you they can reset them for free .
Newman
sumidicsayhuh?
Houston
That's actually not a bad deal . We sell them for 60-70 each for the sensor
AnotherS197GT
USA
S197gt07
Newburyport, MA
1st off, great improvement on the avatar
2nd, somebody getting wheels soon?:crazy:
