KB water pump ?
UNICORN
hey guys ,
I notice on my KB water pump that when I turn off the car several times the pump some kind refill with air which mean it had already air inside I tried to squeeze all hoses to let the air out (while the pump run) but still bobbles on the reservoir and foam so is there some kind of process or something to make it clean from air ?
I don't know like squeeze outlet line first , or the pump should be off , anything?
thanks
zipperhead
Upstate New York
Check to ensure that the inlet hose to the pump never goes below the pump inlet. By the book, run the car with the res cap off until it stops bubbling
UNICORN
thanks man I did but still there is foam on the liquid is that mean there is still some air inside ?
Riptide
Will work for Mustang.
Montucky
Good luck getting every last bubble out of that system. I never could. It still circulates and "cools" like it should.
UNICORN
it is pain in the ass now when I want to take a ride I open the tank cap turn on key and squeeze every hose I could reach for a while .
Riptide
Montucky
Honestly it looks like it flows about the same to me between your vid and mine. How much antifreeze are you running btw? Looks like a lot.
UNICORN
around 30/70 antifreeze/water give or take .
