Steeda double adjustable panhard bar
RSKtakR
Raymore MO
I used this on my 2011 gt after I put drop springs on it to correct the left and right position of the rear wheels after the drop. Fits 05-13 mustangs. Wont be using it on the Boss so its up for sale..$85 shipped.
Shot at 2012-08-22
Shot at 2012-08-22
Shot at 2012-08-22
RSKtakR
Raymore MO
That's the double adjustable? That looks exactly like my single adjustable Steeda panhard rod. Am I missing something?
? Maybe I'm missing something...I just figured it was called "double adjustable" because the ends are exactly the same as the double adjustable lca's I had and they also adjusted the exact same way? I will look it up on Steeda's website tomorrow and correct my wording if its wrong..thanks for pointing that out! :thanks1:
GrabberBlue5.0
Gold Member
Louisville, KY
yes you are. for starters youre missing the nut on the other end. if you look closer you can see both locknuts on both ends
No, those lock nuts are there to keep the rod from shifting the axle, passenger side has standard threads and drivers side has left hand threads. Still only adjusts one way, shorter and longer.
The double adjustable can actually adjust itself up and down as well if I remember correctly. 2 nuts does not mean double adjusting.
