fnfast
Huh? That is for the factory GT Hood scoop and how to make it functional. He is asking for the template for a Shelby GT hood scoop (Two different scoops BTW) so he can mount it on his car.
Finally someone understands. Thank you
Huh??? Maybe I missed somethi........nope doesnt appear I did. Didnt see where you said that, but now that you did all will be forgotten? I soooooooooooooooooooooooooooooooooooooooooooooo doubt it!![]()
Why would you even want to bolt on a chunk of useless plastic? Srsly.
Only after, but whatever. Get over it. Main reason I gave you shit is that you put the same damn thing in two different places.
Now, onto your question.
Yes, they are two different scoops and the main reason you cant find much on it is nobody has done it. Welcome to the wonderful world of having to figure something out for yourself, everyones been there at one point or two.
My thoughts for you, I, myself, would start with the opening between the ribs on the underside of your hood and center it, make a template that you can use to transfer the mounting holes over to your hood.
My biggest advice for you, measure alot and then measure some more. You can only cut/drill once.
Good Luck.
Edit: Pictures or it didnt happen.
BTW I asked for the other thread to be closed since I was getting no help...
Seriously it's fiberglass. Your another one that can't read.
