clearance issues with kooks 1 7/8" headers.
Braselton,GA
Im putting 1 7/8 headers on a 07 gt500 that I have the whipple install kit in to fit a 4.0 whipple under the stock hood with. Question is i have clearanced the drivers side header to the maximum to clear the steering shaft and even with all the spacers stacked onto the motor mounts it still lacks about 3/8". Has anyone delt with this issue by chance and what did you have to do to fix it? Im about to cut the header apart and reroute 1 of the primaries to make this work, but i really dont want to cut these headers up! Thanks in advance.
Jared@Lethal
We had the same issue as well. When the engine is lowered it puts one of the primaries against the steering shaft. We modified the shaft to have a smaller diameter and haven't had any issues since.
Hope that helps.
Jared
Braselton,GA
Thanks for the reply Jared. How did you modify it to a smaller shaft and was the smaller shaft capable of everyday street duty use?
