FordMotorHEAD
The TIRE PIMP !!!
2005 and 2006 Mustang's were much lighter then the 2007-2009.
Other then the car having only a 1/4 Tank of Fuel and the driver weighing 185lbs the following is a list of weight reduction.
38lbs - Factory Battery
11.5lbs - Braille Carbon Fiber Battery
26.5lbs Saved
48lbs - Factory K-Member
23lbs - BMR K-Member
25lbs - Saved
33lbs - Factory Front Sway Bar and Radiator Support
4lbs - BMR Radiator Support and Front Sway Bar Delete
29lbs Saved
116lbs - Factory Driver and Passenger Seats
48lbs - Cobra Carbon Fiber Driver and Passenger Seats
68lbs Saved
186lbs - 5R55S Automatic Transmission with Converter
110lbs - C4 Transmission with SFI Bellhousing and 9 1/2 Converter
76lbs Saved
258lbs - Factory 17" Wheels and Tires
102lbs - Bogart 15X4.5 - 26" Tires and 15X10 - 28X10.5X15S M/T ET Drag
156lbs Saved
87lbs - Factory Front Struts and Brakes
42lbs - QA1 Front Struts and Aerospace Brakes
45lbs Saved
48lbs - Factory 2-Piece Driveshaft
15.5lbs - Custom 3.5" Driveshaft For C4
32.5lbs Saved
83.5lbs - Shaker 1000 Stereo System
0.0 -
83.5lbs Saved
56.5lbs - Catback Exhaust System
0.0 -
56.5lbs Saved
598lbs Saved Total
WOW that's some serious weight reduction !!!!
Awesome Car......
