Power Steering Bypass ?
05GT281
ole' legend lime
Ft. Laud FL
Correct me if I'm wrong, but I thought our cars were hydro-boost? So if you run a short belt to bypass the p/s not only do you have manual steering but won't you also have manual (no power) brakes? I know it's a track only mod I'd just hate to have try to stop my car with manual brakes. Or is it really not a big deal?
AlloyGT
Lurker
Highlands Ranch
Correct...I bypass the power steering at the track all the time, and my brakes are not affected at all.
kleistang
Miami Florida
i had the belt in the trunk, that night u saw my car at the track. but i did not have a chance to put it on. :) i want to see if this thing really works
2k05gt
Manassas, VA
http://s197forum.com/forum/showthread.php?t=10632&page=3
Houston
why not bypass that idler pulley also and just go straight from the alt the the wp to the crank? Correct me if Im wrong.....
Casey4s
Woodbridge, Va
Has anyone tried this as posted in 2k05gt's post? What if you have an underdrive crank pulley?
06vistabluegt
I think the concern with that route is there will be less surface area contact on the WP pulley which might cause it to slip.
bolted3v
Natzifornia
what about the ac?
edit. never mind i searched it and its not worth it.
kleistang
Miami Florida
i forgot to post, i tried this several times, my car was pretty consistent on every pass and i can tell that i did not get any better results, the car ran the same with or without this mod. the only different feeling was the car felt better down the track since you dont have the sensible steering instead its tight
