TheBuzzard
Hi all,
I have a 2008 GT which was imported to New Zealand from the states around 13 years ago. It's a lovely low mileage car in tip top condition apart from one thing... a previous owner either here or in the US has fitted LED indicator bulbs and butchered the harness to install a device (see pics) which I can only assume is an external ballast for the bulbs. The device contains a relay and four small bulbs which flash when the indicators or hazzards are activated.
I initially thought I'd disconnect the device and re-attach the factory wires to the appropriate coloured wires so I could either run a standard bulb or a modern LED which does not require an external ballast. However when I went to do this I discovered that there is more to it and am now feeling a bit out of my depth. I discovered that there are two wires coming from somewhere in the front of the car supplying always on power to the relay. When I unplug them the indicators still work but the brake lights don't!
I'm hoping someone here may have seen this before and can help before I throw myself on the mercy of and auto electrician who may take hours to sort it out. Any help or thoughts will be very much appreciated.
