slvr08gt
My car is idling horrible, smells like its running really rich, and is slightly surging during normal driving. Wont throw a single code but it idles like I'm on a ghost cam tune.
I've replaced or checked the following:
New plugs gapped at .050
New PCV valve
Cleaned the intake manifold
Moved and swapped around the coil packs
Cleaned the MAF
Reseated the injectors/ checked for bad o-rings
Ran a 1/3 can of seafoam through the intake
Performed a compression test. All were within or under 10% of each other
I know how to data log fairly well, but when it comes to interpreting the data I'm a frickin newb, lol.
So if anyone is good at it, let me know what PID's you need me to log and your email, and I'll shoot you the log. I would also be willing to donate some funds if someone could spot the issue. The only thing left that I think could be causing it to run this way would be the front o2's.
Maybe a tuner on here could spot the issue easily, who knows......another week or so of my car running like this and I will set it on fire.
Reason for not taking it to the stealership is because I flashed it back to stock last week and I know they will see the low clock count in the PCM among other things.
Thanks in advance!
Nick
New PCV valve
Cleaned the MAF
Thanks in advance!
Nick
