Whiskey11
SCCA Autoscrosser #23 STU
- Joined
- Feb 24, 2012
- Posts
- 1,644
- Reaction score
- 4
Is there more than one restrictor that you guys have to run with? If not how does. The intake restrictor cause the car to overheat? Not trying to be a dick I'm just curious is all.
All of the press releases on the Mid Ohio protest state that the restrictor fools the MAF sensor's air flow and air temp readings going to the ECU causing it to lean out and overheat. Since they can't tune the car they risk damage every race with that size restrictor on the car.
http://rumors.automobilemag.com/for...protest-at-mid-ohio-161331.html#axzz2SWlYkEkC
Rehagen can probably provide more detail than that.
EDIT: Just finished watching the Road Atlanta CTSCC race. Seems like some pretty crappy driving being done by other drivers in the series. A lot of avoidable contact made by bone head moves but I'm glad that Rehagen was not among the casualty list and had some good driving going on before the race ended under caution. Good luck at your next race and I can't wait to watch it!
