muztangman93
My setup at 16psi and only pulled to 6200rpm 90 degrees out drove the car an hour to get there pulled right in and on the dyno made 680 rwhp on 93 octane. F1 procharger ftw
and thats with e85 or race gas +ported heads + cams + long tube headers full exhaust off road mid pipe (full bolt on car with 2.3 TVS) with the 4.10s its going to be a very big handful on the street with street tires and you will find your self peddling car all the time. My TVS was a handful even with 3.73's and on street tires and 650 instant tq it was a peddle fest constantly backing off the throttle and i have all rear suspension mods including anti-roll bar you will need some rear suspension parts & more tire if your running stock suspension & tire. At a minimum lower control arms, one piece drive shaft, relocation brackets & it wouldn't hurt to have a upper control arm mount such as bmr and use the lower hole. Brent is a Bmr dealer he can hook you up. Also if your running factory ford limited slip it won't last you will need a Detroit true-trac or Eaton posi the true trac is suppose to not wear out because its gear driven not clutch packs like stock ford and eaton posi.Hes not going to track it right? Drivetrain should hold for a while.
I know i have been sharing positives about the Paxton Novi 2200 but want to share the only reality that relates to Paxton & Vortech (same company) is belt changes are not as simple as some kits it took me a few times on and off to get the hang of it the first time you do it its a PITA! especially if you have never done it expect to talk dirty to it #*\<%.
I also decided to run gates green belt HD because of this and haven't had issues since but also consider that mine is pullied for 900 rwhp.
Also 1 negative i had a friend experience with a Procharger D1 one step under F1 is the crank pulley is a double belt style which is better in ways but puts more pressure on crank snout So i wouldn't do a Procharger without having the crank shaft machined with a 2nd key. My friends D1 sheared the single key leaving the crank pulley spinning on the crank shaft his whole engine had to be pulled and disassembled to be repaired.
But the procharger is a nice kit.
I don't like to be the one to rain on someone's parade but your results are not impressive at all. I've seen big bore strokers with a little more compression and head work make that kind of power N/A. Something doesn't seem right.
