GT500 Instrument Cluster
TexasBlownV8
Formerly TexasBlownV6
Central Texas
*** SOLD ***
For sale, used GT500 instrument cluster (2007-2009); very low mileage, somewhere around 5200-5500 miles.
All gauges work (boost gauge not tested), and mycolor works as well.
Ford part number 7R3v-10849-AD.
ejschmidt
I'd imagine it's not plug and play, though, huh? Do you know what would need to be done?
TexasBlownV8
Central Texas
It is plug and play, sort of. Electrically, the plug on the back is exactly the same as the v6 and gt clusters for 2005-2009.
The issues you can run into is where your car does not have some of the features that are typically present in a 2007 GT500. For example, if you do not have ABS, TPS, or traction control, those will show up as errors on the cluster. If you have such issues, the cluster needs to be programmed with your car's "as-built" data to set up what is available in your car. A dealer or other shops/tuners can do this programming.
For example, for my 2005 former v6, I didnt have abs, traction control, nor tps, so it gives me warnings and stuff about those systems; I can get it programmed by the local dealer or my local tuner, but I plan on eventually going with a different cluster setup and it would be a waste of my money to set it up for my car.
But the gauges work properly as shown in one of the pics...(well, that was only with key on, engine off and engine cold.)
and, it is a My Color cluster!!!! :beer:
windycity3v
this would be a great mod would you have to get you miles programed into it right ?
