So looks like my manifold took a crap sometimes last week. I noticed on Friday that my tank PSI was low and compressor was not turning on. I called Air Lift tech support and talked to Cory (if I recall correctly). After some testing to make sure it was not something that can be corrected (you can ground gray wire on the coil to manually turn compressor on) I am going to receive replacement manifold, I also have to replace my controller because of some software change (both under warranty). Cant wait to get it, since now I have also noticed that my passenger rear pressure is not adjusting with preset controller setting.
Jeremy, any idea what changed in the software?, was going to ask tech but spaced out about it. My system is about 8 month old.
