Need advice on resolving low-beams issue
Squiggle05GT
Florida
Hey all, I need some advice on figuring out a little issue
Problem is my low-beams don't turn on, my high-beams on the other hand do as well as my fog lights. I noticed it when i first bought the car, but didn't really care about it, but now I'm at the point in my cars build where I don't plan on adding anything in the future keeping the car as is and just keeping up with maintenance and replacing any parts that go out/break. Are there any fuses I could check relating to this issue? also is it possible to have both the fog lights and low-beams on at the same time if I were to fix my low beams issue? Also my year model is a 2005 GT if that helps out.
Please let me know.
cavero
NoVA
Are they stock halogen bulbs? Or did someone do an HID conversion?
It might be worth starting with the simplest fix first - have you tried another set of bulbs to make sure both low beams aren't burnt out? With halogen you have two separate filaments, one for the low beams and a second one for high beams. Seeing as how most people don't drive around with their brights on all the time (except around where I live), the low beams would burn out first.
As far as fog lights /driving lights go, normal operation is you can turn them on with low beams, but they'll turn off with your brights automatically for legal reasons. You're only allowed to have 4 headlights on at a time and brights count as 2 each
Hope this helps
DieHarder
Please let me know.
Here's some troubleshooting help.
Here's the circuit: https://iihs.net/fsm/?d=40&f=Headlamps. Autolamps.pdf&p=1
And here's step by step troubleshooting for the headlamps:
Headlamps: https://iihs.net/fsm/?d=389&f=Headlamps.pdf
Pinpoint tests: Low Beams inoperative: https://iihs.net/fsm/?d=389&f=Headlamps.pdf&p=13
Worth your time to read all of the sections starting with Description and Operation; then Diagnosis and Testing: https://iihs.net/fsm/?d=387
Note: the online manual jumps around a bit so you may have to search around to follow some of the sections. Still, better than nothing.
07 Boss
Sin City
My headlights stopped working along with my horn a while back. Suspect it may be the SJB but never really investigated. I have aftermarket HIDs so I just took the fog light relay and hooked it up to the headlights to get home and it's been that way since. I currently don't have fogs because of this but I can't remember the last time I actually turned them on.
Squiggle05GT
Florida
Hope this helps
Yea the original owner had in incandescent bulbs for everything in the front, I replaced all the bulbs with New SEALIGHT H13 H10 LED Light Bulbs and it made a huge difference at night, especially the turn signals pretty bright. I tried seeing if my lowbeams worked then, but still nothing, I don't know if it might be turn-switch inside the cabin? where you adjust your lights. but yea I've been using my fog lights at night, but will use my highbeams if the road is too dark.
cavero
NoVA
They didn't even work with the incandescents?
