Experience with Antigravity Lightweight Battery??
foolio2k4
Buena Park, CA
the antigravity doesn't list the cold crank amps.
I have been running the Odyssey 680 for the past 2 years now.
takes a few seconds to crank when its cold (50-60 degrees). Wont start if left for about a week.
o2sys
So what do you if you leave it for a week and doesn't start? Just jump it? Does the alternator then fully recharge the PC680?
csamsh
OKC
If it were me I'd just leave it on a conditioner.
Alternators will recharge a battery to a point. I don't know the exact chemistry that the PC680 uses- but with lead-acid batteries, various sulfate precipitates will form on the electrodes if they're left untouched, and then they can't be re-dissolved and are non-conductive, so your voltage will drop.
DTL
SoCal
I've never tried to leave my PC680 sit for more than a few days to a week max. Then again, my car isn't a DD. I don't think I'd be running that battery if I either had a high-option car, big stereo, etc. or if the car was required for daily transportation in inclement weather, etc. Mine stays on a Battery Tender whenever it's going to be parked for more than a couple days. (which is basically always).
2011/5.0
Iowa
Thanks. Looks like the packing foam just happened to fit battery tray
2011/5.0
Iowa
My oem battery is roached. I will be picking up the b3121 braille at 21lbs and 550 ccamp for 225 if u get the odyssey pc 680 at 170 ccamps and 15.4 lbs u need u get the trickle charger for another 100 plus the 155 for the battery being i live in iowa and run march to oct. Its a smarter choice. Thank for the info guys. Ill go to the gym and lose that 5 lbs. lol
o2sys
You can get the same battery but without the $$ name for half:
http://www.baltimorebattery.com/deka-etx-batteries/deka-etx30l-agm-maintenance-free-battery
2011/5.0
Iowa
Closer look at that braille its flipped on its side. The deka is a good price for 400 ccamps but i dont see the post to bolt in to use oem hookups
FordFan
My car is driven limited and kept on a Battery tender when parked for more them a week.
The Braille has worked great or me. Small enough but still powerfull like a standard battery, handles the demands of a day on the road course and dependable enough to drive on a 3k mile road trip (like I did in 2012).
The B3121 comes with bolt on posts that can be installed in two different configurations, this allows the battery to be mounted in many different ways.
http://www.braillebattery.com/index.php/braille/product_batteries/b3121
The B3121 weighed in at 19lbs on my scale compared to the oem Motorcraft at 31lbs.
The Braille has helped bring the weight of my SGT down to 3706lbs including me.
https://www.facebook.com/bradscusto...7546825568.534252.204217375567&type=1&theater
Iowa
Did need a special charger or can i use my old 2/10/50 set at 2 amp
FordFan
After reading up on how a battery tender works you won't consider anything else for battery maintenance. Readup at batterytender.com
I have 3 ponys hooked up to them during these winter months.
To this day our 2001 Roush is still starting on the original battery.
