Will these clear the Brembos?
Arustik
I have the 4 piston brembos with 14" rotor. Wondering if the 18s off the 2013 Mustang GT will clear the calipers.
Picture attached.
Arustik
Here's another OEM set I can pick up, will these clear the brembos? These are called "Fanblade" wheels also in an 18".
frank s
at Play
Paradise
The "Fanblades" clear the '07-'09 GT500 Brembos if you use a 25mm spacer. The other Ford "Bullitt-style" 8.5" wheels require shortening of the wheel studs by 5mm in addition to the spacers. Fanblades have voids in the places that make the shortening necessary.
http://www.mustang-gtcs.info/mods01.htm#gt500
Arustik
Thank you all. Consensus is 25mm spacer on front to clear brembos. Seems easy enough!
frank s
at Play
Paradise
The strategy is easy; tactics is where the Bullitt-style could be difficult.
The spacers referred to are the add-a-new-set-of-studs-as-well type.
Dubstep Shep
WUB WUB VROOM VROOM
Houston, TX
I have 1" spacers that are the second set of studs type and my factory 2008 Bullitt wheels clear just fine with the four piston brembos
frank s
at Play
Paradise
The second option will surely fill the bill, but requires removing the original studs and pressing/pulling in the new longer ones. The ones I have experience with are THESE.
RetroGT2006
06 S197 Member
Florida
I refuse to run spacers on my car, I loved my fan blades but I don't want to risk running a spacer.
Dubstep Shep
WUB WUB VROOM VROOM
Houston, TX
There really isn't much risk running a spacer that's properly installed.
That would be the same thing as saying running a washer on a bolt is dangerous.
Is it TECHNICALLY less sound that if you don't run a spacer? Yes
Basically the torsional shear generated by the torque is transferred through the friction of the spacer on the wheel and hub, and when the torque exceeds that frictional force, the torsional shear acts upon the lug nuts in two places instead of one.
Does it matter on 99% of street driven cars? I seriously doubt it.
You'd have to exceed the frictional force generated by what I imagine is a MASSIVE clamp load. Probably not anything you could do without drag slicks and a ton of horsepower.
TGR96
el blanco nino
Huntsville, AL
Gotcha!
I have experience with the bolt on style wheel spacers as well. My only issue with them was that the car was harder to keep the wheels balanced when running those up front. Mine were the Eibach Hub-centric spacers from American Muscle.
