Maybe airlift should look into making a custom visor for the drivers side that has the buttons integrated in... Like some come now a days with buttons that are programmable for garage doors and things like that.. Just an idea.
last i heard they were busy making an app and dongle for phone/tablet control.
btw jeremy, how far is it?
Looking good, never got around to doing it to mellow 06
But mellow15 is a whole new story for the SEMA 2014 booth
Great pics and progress so far Scott!
great write up Scott, going to make doing my install one of these days easy..
Scott, have you thought about using a spacer on the bottom of the leg where it bolts up on the floor to raise the tank up enough to clear fitting?
spacer should make it an easy fix...would be better than changing out the 90 on the bottom.. just an idea..
Yes, but the issue with the spacer is that I want to keep the tank below the oem trunk floor. Wes06 built a platform and raised the trunk floor. I was hoping not to have to do that. If I can't get it to work with the space in the tire well I may have to mount the tank behind the seat. GallopingFord has the same tank in the tire well, will have to check with Cam on whether he is using the bottom fitting for a drain/fill line.
