smoken1986
I had idle issues with my 12 auto with and without my lt's. Got really bad after the jlt CAI. I changed tuners and now no issues.
ALOT of people use lunds base files including danner
Never had to do this and my car idles and runs fine and has done so for the past 2+ years. Adaptive learning should take care of it.
I left adaptive learning turned on in my tune and my car never adapted, it had a lot of stalling issues when I first did the long tubes. I think some strategies adapt well and some do not unfortunately I was one of the ones that did not adapt. I have since then modified the o2 transport delay to rectify the issue at idle and my car idles smooth like stock. I still have adaptive learning turned on in my tune but I don't think it does much for my car lol.
Danner gets his shit from lund
Danner doesnt use SCT to tune.
Neither does lund or any good tuner. ALOT of people use lunds base files including danner
what does he use?
Hmmmm. Ok... i heard quite a different story but all is good
That is pure fabrication on your part.
My new CAI has seemed to solve the tip-in stalling issue and recovery issue so far and it isn't even remapped for the 123mm maf vs the 110mm maf I had on it.
Sent from my iPhone 5S
I'm sure you know that your tune needs to be adjusted. Have you checked how far the fuel trims are off? If you ever end up in open loop it will go lean.
It's quite possible that you had an air leak with the other cai.
Are you saying that Lund supplies open mako file tunes?
What does he use?
Base files? Is that the same as value files? Lund makes his own value files from scratch?
Ditto
What did you hear and from where? If you can post the information you should have no problem posting the source. Especially when it's something that could potentially affect someone's reputation.
He uses a computer to tune
Me too!, coincidence?
I think we all use computers for tuning.
Crickets. He sure replies in other threads here though.
