Grubb
Rip the tint then use 409 to help remove the glue, the correct product is called Simple Pink. We get it from a tint supply company. If you use razor blades on the sides make sure they are Stainless Steel or they will scratch the glass. Also once you take the blade over the factory etching or edge of the window the blade is wasted use a new one. Been in the tint industry for 14 years it just takes time. It's also easier to clean the mess if you pell it 70% down and let it hang while you clean the top half so it catches the mess.
