Still seems off for your mods. That should be a 11.5 car.
Glad you got in the 11's, also glad you admitted you gained nothing with the gear change. Next time listen to us LOL. You are trapping well, I think your car has another tenth or so in it. What was the DA?
To many variables, track prep, DA, etc, etc. I think he is close to where he should be for his mods.
100% stock engine, 100% stock exhaust, 100% stock suspension, heavy 3800 lb car. 11.5's will take another 40-50 hp to achieve.
I'll split the difference. Fine tune the tune and I'm calling it a 11.7 car. Other autos are getting 12.2 in good air with the stock converter, street tires, off road pipe and a tune. With your 60 there's more there than a 11.9.
I'm contemplating an off road pipe, but I'm in a California Emissions state so my exhaust is 100% intact still. 11.70's sure would make sense in my car with an off road pipe.
Hope I can jump in here and not hijack too bad and get a little advice. Maybe some of you more experienced guys can offer some tips?
I'm running a Circle D 4C with 275/60/15 MT drag radials, 3.15 gear, AED tune,single piec aluminum drive shaft and a lethal off road H pipe. Best i can get dead hooking are high 1.7 60' times.
Are the 275/60's too tall for the 3.15s? Best ET is a 12.02 @113.8 at US131 at Martin yesterday. DA was about 1500. I will admit this is a heavy car at 3900 with me but I expected solid 11's. When I launch the car it almost feels doggy until a little ways out.
Just loading the converter a bit, then leaving on last yellow. That was the best ET. Leaving at idle was about a tenth slower. I should have tried getting some more rpm before launching I guess. Running 16-17 psi in the tires.
