2011+ Sticking clutch pedal fix
Morris
Well, I can now confirm the shifting is much better with out the fucktard spring. Ran a 12.26 on street tires tonight.
Morris
Thanks, my 60' was 1.89, trap speed was 116. I think I'm tapped out though, with out some tires or power adder I doubt I'm going to do much better. Perhaps a few 100 ths with good air but im going to have to spend some money to see 11's.
char259
Wolf Pack Racing
Mechanicsville MD
isnt that always the case, good luck!!
ArizonaGT
Road Course Member
Phoenix, AZ
I did this last night, going to see what effect on driving sometime this week. Thanks for the write-up!
steve13gt
Ive done this, and upgraded my brake fluid to motul 5.1... Out of no where the other day my clutch engagement was a half inch from the floor, drove for a minute and it went back to normal
Zodiac
Cary, NC
Impressive times Morris. I need to get back out to the 1/4 mile strip again.
KonaBlue11
Can someone help out a stooge like me and confirm whether the spring is the only part being removed from the assembly? Or does the two other parts shown in the second photo on page 1 also become obsolete?
I can follow every step in the very simple instructions, but it's not clear if those other parts somehow need to be reinstalled.
Thanks.
nasty281
MODIFIED STANG
memphis
Thanks.
It says remove spring reinstall everything else
Gabe
Whippled Coyote
Everything in the pic gets removed and stays removed
302GT
Charlotte, NC
That black piece is still on my car. It just hangs there. Doesn't get in the way or make noise.
Chris1229
Sarasota,FL
My clutch was stick at the track last night got pissed off, found this fixesd the problem . nice write up my man!!
GallopingFord
I'm Cam - Mr. Indecisive
Northern Virginia
Well, I guess I'm going to have to do this. Took the car out on Saturday for one of the best joy rides and at a 6K shift it stuck to the floor.
draxxus131
Try upgrading the pressure plate, this will most likely solve any issues with the clutch sticking.
