2011+ Sticking clutch pedal fix
gizmo5
Italian between my legs
I don't see why the hydraulic clutch needs to be easier to push, it's cake already.
My hypothesis to this phenomenon is that Ford allowed a vagina to be employed in the pedal assembly design department. Therefore allowing someone to insert a spring assist... Ergo making it a less awesome design than the GT500 unit.
:highfive:
iceguyb14
Mustang Fanatic
Fredericksburg, VA
Oh god you gave Iceguy another reason to create a video.....lol
Lol hey gotta keep making videos! And considering there are actually some people out there who aren't on this forum to see it and it's a good quick fix for the issue, the easiest way for me to spread the word is to make a video. I've got over 1600 subscribers and almost 400 likes on fb, so why not help them out? I wish someone would have posted this several months ago so I could have known the easy fix lol.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Seer
at least the coyote can bang second gear, unlike the gt500.
Drunk Racers
Hawaii
For those that have "clutch sticking" issues, I have a few questions....
Did the clutch stick under WOT or did you experience it during "normal" driving?
What symptoms / indications did you have with the clutch sticking?
I am asking because I am suspecting I am having a similar issue that could be caused by the spring. I have noticed sounds/vibrations that indicate the clutch (slave cylinder) is engaging slowly causing the clutch to chatter or slam (as if I dumped the clutch).
I am thinking it could be the assist spring is not allowing the pedal to come up as fast as my foot is engaging the clutch.
07TGGT
@user
Mansfield, TX
If you simply search "clutch pedal sticking" you will find the answer.
I noticed you have a V6, I don't think I've ever heard of the V6s having issues with sticking clutch pedals.
iceguyb14
Mustang Fanatic
Fredericksburg, VA
Basically when driving the car hard, at high rpms (7k+) the clutch pedal will basically become almost fully depressed making it difficult to shift. There aren't really any increased sounds/vibrations or chattering of the clutch that I experienced.
Hmm good point I don't think I have either.
gizmo5
Quick update: Lots of hard pulls, and redline shifts, not a single stuck pedal. It's 100% fixed.
jukens
Just noticed a slight whirring noise coming from the transmission while in neutral that goes away when I press the clutch pedal in even the slightest it goes away. Almost as if the tob/slave cylinder is riding the fingers too lightly. Has anyone else experienced this after removing the helper spring?
07TGGT
@user
Mansfield, TX
Nope. Mine is quite as can be.
Geo2JZ
I can't wait to do this tomorrow. It's the only thing I don't like about the car.
302GT
Charlotte, NC
After reading this I went out and yanked mine off. It now reminds me of my '04 Mach 1. Stiff and consistant. It's just too mushy with that spring on there. Will have to take it out when the kid isn't in there so I can really test it out.
cgibs89
Stickers add HP brah
I finally got around to doing this since I got my car back from the body shop. My dumbass forgot to pull the cruise control deactivation switch and broke all the plastic holding it in. Now it's gorilla taped in there. :lol:
As for the actually removal of the spring; It was easy. The outcome? Outstanding. I haven't been able to go too crazy as it's been misty/raining the past few days but even 75-80% throttle to 7k and the clutch doesn't even think twice about popping back. I love it.
GTOdude
Farming goats/ponies
Merced CA
That has got to be the most idiotic thing ive seen on this car (next to the sound tube). Im gonna pull mine out soon. I'll assume the clutch will have a much better feel to it..
