Progressive Methanol Controller
TexasBlownV8
Formerly TexasBlownV6
Central Texas
For sale: a Devils Own progressive methanol controller, using boost to control the methanol spray rate over a varying boost level. The controller has a build-in map sensor for sensing boost; just wire it up, connect vacuum line, and go!
Adjustable start setting range is form 2-17 psi, and full on is from 5-20 psi.
This has been in my car for 1 year, and activated under power about a dozen times. (I had a switch wired to the power to turn it off and on manually; switch not included).
No issues at all with the controller, it worked fine. I am selling it because I switched to a different setup.
$165 shipped, with extra wire, connectors, and hose as shown.
TexasBlownV8
Central Texas
Bump. Will substitute a maf-based voltage controller instead of the boost-based controller, if that is what you need.
