eighty6gt
- Joined
- May 9, 2011
- Posts
- 4,306
- Reaction score
- 416
How many seconds in the 1/4 do you get by ditching the stock driveshaft?
After 4 rear ends including a Truetrac and a wavetrac I went to a 9" and couldn't be happier.
Buy once cry once.
Which one did you get? I want one...its my last mod. Was it completely bolt-on?
This is a CAI/tune street car. 9" is overkill to say the least lol. It's an iphone app called iAngleFinder. I like the Tremec app much better though.
I know what you're saying but the first 2 times I did the diff I was N/A also.
The problem is you tell yourself that this will be the last time.
Next thing you know you break a pinion gear so you buy all new bearings again and you then add a Truetrac so there goes another $1100.
Then you go forced induction and blow that up and you're at the same place but this time you put a $1000 Wavetrac in plus all the other parts and you just spent more than the whole 9" setup.
The whole 9" rear setup is not expensive at all when you consider the cost of a T-56M XL, blower/turb setup, etc...
You can pick up a whole bolt-on ready 9" from Moser and Strange for a little over $2,000; a bolt-on ready for 05-14.
I've got a solid spacer in there already, and I just drive it on the street with street tires.
I did some more driving today and it seems that the vibration has moved itself to 90+. I'm not sure if I should bother having the rear end taken apart and the gear done again. With my luck it will come back 10x worse. Maybe I'll just trade it in for a 5.0
I really think that its a gear issue and the DS amplified the problem being that it takes up more slop. Unfortunately, I think I will be selling the 1 piece and sticking with the clunky shitty stock DS.
I have been emailing back and forth all day with Coast, and I'm very impressed with their level of service. I came right out and told them I bought the DS second hand and I want to check the balance, and asked for a price. He's been asking me questions all day about my driveline angles instead of just throwing a number out there.
I am having the same problem after 90mph+ I get a vibration. I just purchased the car at a dealer it's a 07 gt 5 speed. I noticed it has rear lower control arms, paftermarket pan hard bar , aftermarket swaybar, aftermarket and links, they all have polyurethane bushings. And I'm guessing it has gears because my miles per hour gauge is off by like 15 to 20 mph. And it's lowered. Anyone find the reason? Btw just check I have stock 2 piece driveshaft
