FIRST LOOK at the S550 IRS !!
Jared@Lethal
FIRST LOOK AT THE S550 IRS !!
Our friends at The Driveshaft Shop (www.driveshaftshop.com) sent us over some killer pics of the new 2015 Mustang GT IRS rear end. We'll post more info on our site as we get it, so keep checking back. Also, Make sure to LIKE & Follow Us on Facebook , Twitter , & Instagram for all the '15 Updates!!
The Factory '15 Mustang Driveshaft is designed as a 2-piece assembly with only one CV Joint.
LethalPerformance.com will be your place to buy 2015 Driveshaft Shop Halfshafts, Axles, Driveshafts, and their 9" IRS Upgrade!
For more photos of the IRS, Visit : http://www.lethalperformance.com/info/2015-ford-mustang-gt-first-look-at-irs !! #teamlethal #dss #svtperformance
TeamLethal
BadPiggy
Hooligan Ahole
Knoxville, TN
Goodness I would shit my britches if that could bolt into an s197.
Anything can be done.....with money.
I see a plethora of BMR parts on the horizon...and then copycat UPR parts soon to follow.
:bravo:
DiMora
More Is Better
Fayetteville, GA
:bravo:
Kelly...whatcha got cooking? How bout a BMR tubular bolt-on huckleberry that adapts the '15 IRS (or an upgraded 9" with a True-Trac) to an S197?
tjm73
of Omicron Persei 8
Rush, NY
Why would anyone need the 9" "upgrade"? The 8.8" is very tough. But the new IRS is supposed to have the "Super 8.8" which is supposed to beefier.
Dubstep Shep
WUB WUB VROOM VROOM
Houston, TX
9" is a far superior setup, both is size and design. It's modular, it has an end bearing on the pinion, it has a larger ring gear, etc. I agree it's overkill unless you're putting some amazing power down though.
I still like a well set up live axle more than IRS on these kinds of cars. But that's just my opinion.
irishpwr46
Official Site Vandal
NYC
looking at the framing, it doesnt look like it will be an impossibility to make this adapt to an s197
tjm73
of Omicron Persei 8
Rush, NY
The 9" has two maybe three superior design points. 1.) the pinion supported by the second bearing. 2.) the 3rd member allowing relatively easy & quick gear changes. 3.) If it's a stick axle, the 9" has captured axles and that's way better than c-clips.
I have lost the source, but many years ago I read that the 8.8" was like 90 or 95% as strong as the 9". This IRS has this new Super 8.8". I'm curious what the stock versus stock power capabilities between the Super 8.8 and the 9".
As far as aftermarket support goes. 9" is better supported.
DRock
I want that to bolt up!
Someone go find Kelly!
19COBRA93
Ford Racing
Clinton, Ut
No rear sway bar?
And those multiple pivot points are going to help eliminate the negative camber on launch and when lowered.
BMR Tech
Traction Vendor
Tampa, FL
We will see what happens. If it is possible, we may have several solutions. This IRS into an S197 would be nice.....and I'd also like to look into offering a 9" center and better halfshafts, etc...for the IRS....like we do for the 2010+ Camaros.
Speaking of.....we broke a halfshaft in our 2010 Camaro over the weekend. It is a 9" center upgrade, with a bunch of BMR parts including 1000hp half shafts. I have some cool under car footage, it's pretty cool.
No rear sway bar?
It has one, just not pictured.
BMR Tech
Traction Vendor
Tampa, FL
You can see a lot of run-out on that shaft as the burnout starts. It's likely it was already hurt before that launch. Cool to see though.
I said the same thing, but was told that this is how they always are.
I won't argue, my GM guys here are pretty sharp....but I dunno. lol
I will say, that run-out couldn't have helped any. The shafts just straight up sheered clean.
19COBRA93
Ford Racing
Clinton, Ut
How could it not create some sort of vibration when it's wobbling like that? Interesting.
I'm real interested in this new IRS from Ford, and how it may hold up to abuse. Initially I was concerned with the difficulty of gear swaps, but it appears they have designed the frame to allow the housing to be removed with little work.
Shotokan1509
CT
Hopefully that can be done, and better than it was on the new edge cobra's. Funny I was watching drag week coverage and there was a Datsun with IRS from cobra swapped in
ZmanM3
The Evil One
Jackson, NJ
You got my attention with IRS into S197! I'll be waiting at watching!
