weather man
Persistence Is A Bitch
Good share.
the ecoboost ran a 12.56... vid link http://youtu.be/Kulx2AfNZuY
Damn, treed me by 25 minutes. But I'll embed the video.
Man... awesome 60' times on factory suspension.
The real thing to take from that is the upgraded rear sub frame they put on. All three models had it. Which one is the weaker point? The half shafts or the sub frame? Most guys will go straight for axles I feel, leaving the sub frame. Or leaving both stock, throwing on some sticky tires and cracking the sub frame. That wouldn't be a cheap or easy repair. I feel that if they took the time to upgrade it, it will be a necessary mod for the track and hooking and setting those 60' times safely.Ford is gonna sell a lot of the upgraded half shafts.
The real thing to take from that is the upgraded rear sub frame they put on. Which one is the weaker point? The half shafts or the sub frame? Don't want to see guys upgrading axles then cracking their sub frames. Or leaving both stock, throwing on some sticky tires and cracking the sub frame. That wouldn't be a cheap or easy repair.
That makes me feel better. It got me wondering if they cracked a couple in testing already.It's not a upgraded subframe, it's only subframe bushings.
