*edited to include data in the correct format in addition to all my rambling below*
- Shocks - strange single adjustable
- Rear springs - cobra jet (m-5300-q)
- Struts - strange single adjustable
- Front springs - cobra jet (m-5300-q)
- Lower control arms - metco
- Relocation brackets - BMR
- Upper control arm - metco (with metco UCA mount)
- posi/diff - eaton truetrac
- Pan hard bar - competition engineering adjustable
- Pan hard bar support brace - competition engineering
- Gear size - frpp 4.10
- Brand/ tire size - M/T ET street (bias) 26X10.50-15
- Clutch or which converter at what stall? - OEM clutch
- Anti roll bar or which rear sway bar - OEM sway bar (no arb)
- 302 rwhp
- 3490 lbs race weight
pinion angle set to -2 deg
LCA set to middle hole on BMR relocation brackets
UCA set to uppermost hole on UCA mount
12.339 @ 108.86, best 60' of 1.611
test & tune / midnight madness at MIR last night (24OCT14): my times continue to trend down!
weight 3490 with driver/helmet, 1/8 tank of gas
pass seat and rear seat bottom/backs removed
ps delete belt
front strut full loose
rear shock +7 clicks from full soft
15psi cold in rear tire
6500 rpm launch off limiter
pb 60 = 1.611; 1/8 = 7.819; 1/4 = 12.339 DA was between +99 ft and -299 ft throughout my runs per drag times calculator
Spun bad on the third pass after following several street cars that drove through the water box
I missed 2nd gear on the last pass, it may have bested my 12.339... There's still some tweaking to do with tire pressure and shock/strut settings. I may have a high 1.5x 60' left in the car, and maybe 12.2x ET by years end.
