Congrats!
Gotta love sea level DA !!! Congrats !!! Now update your signature...
Congrats!!! I obviously got to get my 60ft's down...Thanks guys! I will get on the sig update right now! LoL
When does the converter go in?
Are you launching off idle or power braking?
Converter went in last night
congrats on hitting 11's!
looking forward to seeing your new numbers, I'll guess 11.61![]()
I'd guess the same, mid 11s
OP, have you had the car on the dyno with the exhaust? what did it make?
What size rear tire do you have? And what psi do you lower them too?What rear tire and psi are you running now? I had to make a large psi adjustment after adding stall
Ive had good luck with the 295/55 at 18psi. You should be in good shape
Usually 1.60 range on my 4c. Iirc your shift points go off the speedo so make sure you run the tires you told mike to write tune for or shift rpm will be off
