Well we should have had it on dyno Wednesday but that isn't going to happen thanks to our latest discovery.
Finally got the scavenger pump worked up and went to test is and no Bueno!
This came used with the Hellion kit and looks like someone blew a motor or a turbo who used it last
Lots of guys running these pumps on YellowBullet.
It's not a TurboWerks pump but it's way cheaper. If it fails later I will goto a TurboWerks pump but that's $250-400 depending on which on you go with.
This pump is same as a STS pump
I am waiting for a oil restrictor fitting to get here. My car make 100psi of oil pressure and it is pushing some oil through the seal of the turbo. BorgWarner based Turbos are real sensitive to oil supply pressures.
I am gonna try a .060 restrictor and see if that solves it if not going to a .032
