BMR UCA not lining up with the axle bolt hole
justinsstang
I got the UCA attached to the mount, and the mount is all installed, but the end of the UCA that attaches to the axle is too long. I shortened the UCA (I have the adjustable one) to it's shortest position and it's still too short.
Does this mean the axle shifted forward even with the PHB/LCA/Sway bar/all that jazz still hooked up? Guess I need to put a jack under the axle and try to push it towards the rear once it's up? (that'll be fun. ffs sometimes I wish I was fat so I didn't just slide away when I pushed on things lololol)
Any tips would be great, got the rest of my suspension all hooked up and almost ready to roll once I get this UCA finished and the wheels back on. :peace:
AnotherS197GT
Serial Valve Dropper
Tampa, FL
The axle will rotate forward without having the UCA there to prevent it from falling forward. Jack the rear up, and put some muscle into it and you'll be able to get it back in line.
justinsstang
Got it, woohoo, done! Lol. Now I just need to get an alignment today
claudermilk
SoCal
:LMAO: I get that. I gets annoying pushing yourself around under the car when you mean to move a part. Look at it as a puzzle and workout wrapped into one.
Wes06
I used ratchet straps to pull things back together.
Works on exhaust to. Lol
Riptide
Will work for Mustang.
Montucky
Yah it sucks if it shifts on you. Normally that doesn't happen. In fact I've never had it happen with the upper. But it has done it to me on the lowers. It's easier to straighten out with the lower arms if that issue comes up.
Ratchet straps, long screwdrivers, elbow grease, etc. all come in handy there. My friend and I had no straps and we ended up using the spare jack to help push off and get it lined up again.
justinsstang
I just lifted it with my jack a little, got under there, and kept jerking on it (LOL). After many jerks and scooting back behind it since every time I pulled on it my 150LB self moved in the opposite direction, I got it far enough back that I could put the bolt through haha. It was a process xD
