M
MattD
Guest
I'm gonna go ahead and step up to a 150 shot. I've got colder plugs on the way and I can turn my timing down with the Diablosport. Anything else that I should be prepared for?
I still don't know exactly was caused the nitrous backfire. The engine still turned over, but alot of stuff above the clyinder heads were destroyed. Hood, windshield, intake manifold, fuel rails, etc. No fire though, so I was lucky. I think something held an intake valve slightly open, and the combustion traveled from inside the cylinder into the intake manifold, then boom!
I'm pretty sure all that info is about 6 months old now... his rebuild is done and he's running low 7's with the Whipple now.Man that sucks! I am glad you are ok though. So looking on the bright side, are we going to see a rebuild thread? And a thread about what happened and what you found?? Again the important thing is that your ok and no one got hurt!
yea i think the HTO would be better but, what did you ues?
What are you using for your fuel system? BAP?
Confirm your a/f with either your wideband (if you have one) or the dyno, I ran a fuel jet .003 larger then called for to get 11.5 a/f. On the 150, use the best gas you can get--at least 100 octane--cheap insurance and your plugs will live longer. I stuck with the stock gap with the 125 shot, but when I went with the 150 shot, I gapped them down to .035.
What tires do you have? If you have some good dr's, then great. If you don't, then don't bother, you just going to spin the tire anyway unless this is for 3rd gear and higher.
Lastly, make sure you have a window switch. I made literally 175+ nitrous passes squeezing right out of the hole (auto, aftermarket 3000 converter), so I thought I didn't need one. When I went to the 150 shot, I had probably a good 20 passes or so, maybe more, then this happened:
BAP = Boost-a-PumpExcuse my ignorance, but what is BOP?
