SSP's 900+RWHP Turbo Streetcar
swflastang05
Back for More
N. Ft. Myers, FL
New tires got here today!
Notice how well the sidewall flexes with little pressure they should work well.
Nice! I'd be interested to see the actual height of these tires after they're mounted.
onebadgsx
Houston, TX
these are actually drag only non d.o.t just fyi for those thinking you can use for street classes. but should be bad ass tires
Gabe
Whippled Coyote
Awesome!
What did you run?
Any dyno numbers yet?
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
Awesome!
What did you run?
I broke the left lca it went hard right off hit and then spun. I had to let off the get back on it. Trapped 138.8 mph but ran 10.60 on only 10.5psi of boost in +2900DA @96deg
It would dead hook go right and blow the tires off
The carnage from it breaking the lca it ate a hole and pulled side skirt down
Going to pull the 6r80 setup this week and start the transformation to the TH400 turbo-glide and spool and 35 spline axles and going to do a TRZ rear suspension kit with ARB. Had 20psi in right air bag and it still twisted hard.
I can say those new M/T Pro-Drag radials hook hard!
fiveoh
Selling the 6r80 stuff?
fiveoh
Yeah I got a buyer supposedly lined up.
It's built 6r80 with Exeedy clutches and shaft with Circle D 258mm 2B Shaftmasters driveshaft the whole swap. Cooler lines, cooler, select shift shifter, etc $4k
Lmk if it falls thru, although I'm not sure about a 13-14 going into an 11 without select shift...
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
So you got the car running, ran it once, and now you're tearing it down again?!?!?!?!?!?!???
cuz race car.........:Violin:
Gabe
Whippled Coyote
Don't post them here. UPR will steal them for advertising.
One pass is more mileage than he sees in a month lol
:signs6::fishing1:
It's funny cuz it's true .... lmao ...
On both counts :evillol:
