5.4 DOHC swap setup for S197, off of running show car swap
dream07
Eastern PA
ALL SOLD!!!!!!!!!!!!!!!!!!!!!Practically gave it away!!!
dream07
Eastern PA
Sadly, I am starting to think about parting this out. I figured there would be interest, but apparently everybody just wants the intake manifolds???
irishpwr46
Official Site Vandal
NYC
you would probably have better luck selling the whole longblock over just the intake manifold.
dream07
Eastern PA
HP depends on what cams, head flow, etc. matching that compression, but if you just want a ballpark number I will give you one. Assuming a purpose-built engine, figure the 5.4 is 50 cubic inches bigger than a 4.6, so using the same basic compression/cams/heads with this intake figure it will be about 40-50hp and 40-50 ft-lb torque more than a 4.6 DOHC built with same specs. The 5.4 has an enormous 4.165" stroke and can build more bottom end torque therefore making it more streetable than a 4.6 at any given HP level in naturally aspirated form.
The stock Navigator engine produced 300hp @ 5000rpm and 355 ft-lb @2750rpm. It came at 9 1/2 to 1 compression and low duration cams (5000 pound SUV meant to pull rich people's boats and stuff). If you put this intake on a stock Navigator long block, that is the same 300HP you will get. You can get Probe 5.4 pin height forged flat tops for cheap at Summit and have over 11 1/2 to 1 compression, stick in 96-98 Cobra cams, this intake and have a nice torquey engine with 350hp for cheap. Personally, I prefer the 03/04 Cobra heads over the Navigator heads, so I would start from scratch instead of looking for a Navigator engine (plenty of 5.4 sohc blocks out there).
dream07
Eastern PA
OK, here goes:
Aussie lower - sold, but I can get it back to make a package deal
Fuel Rails - sold
Aussie Yella Terra upper - $500 shipped in USA
upper will include free modified GT500 t-body as shown
the cold air setup as shown is +$100
widened coolant crossover - $200 shipped in USA
dream07
Eastern PA
Alternator is from Advance Auto, standard output, 200 miles on it, mint condition. $50 FREE shipping in USA (keep it for a spare)
dream07
Eastern PA
SOLD!!!!! Thanks to certain incompetent Veteran's Administration employees.
