at what point is it best to add an intercooler to a whipple 2.3 ? would it make enough of a difference to add an intercooler to a 2.3 that's running only 6-8 lbs of boost ? trying to get opinions on the set up. the car is an auto with exhaust only
How does the non intercooled FRPP 2.3 whipple kit even work..with 400+ rwhp ?
The iat's, even with low boost, must be outa site. A couple of years ago, Justin at VMP tuned a non intercooled 2.3 whipple. He noted the air coming out of the blower was so hot, it expands, increasing the boost even more.
If you built a sophisticated methanol injection kit that sprayed directly under the blower outlet you could easily achieve 500 at the wheels with no intercooler, no pumps, no exchanger, etc... however a tank in the trunk and a pump. That would be neat.
*caveat being I only know about how well methanol injection works from 1000's of internet postings I've read. Should drop temps by 10 to... I don't know, 80 degrees?!? No way of knowing.
I wonder if Bruce was on E85. With that you probably wouldn't even need the meth.
The iat's are really low. Whipple made their own rotors based on their own design for the 2.3. They run cooler than any other pd blowers I'm aware of.
Cruising iat's would be around 120-140 in the summer. They would go up at a stop but come right down once you got going.
This is my actual experience. I watched iats all the time when I was boosted. Going from non intercooled to intercooled lowered iats to about 10-20 over ambient for normal driving. Compare to 50+ over ambient for a little M122 during normal driving.
Whipple spent the money on engineering and rotor design. It's why their blowers run cooler than any other twin screw out there. They were forced to do it when Lysholm held their 1st generation rotors from them but still supplied to KB some years ago. Whipple ended up with superior product and KB kept their supplier designed parts and propaganda.
What were the IAT's at WOT?
If I have the story correct, FRPP offers 3 options for their 2.3L whipple kits. 1st one is listed at 5-6 psi..and 400 RWHP. 2nd one is listed at 9 psi + 475 CRANK hp. 3rd one is listed at 11 psi + 550 CRANK hp.
1st one doesn't have an intercooler / HE / pump etc. 2 + 3rd option do. Option 3 has the GT-500 pump etc.
Option #1.... but with the IC / HE etc, would result in the lowest IAT's of the bunch.
The whipple rotor pack uses a 3-5 ratio. The K Bell rotors use a 4-6 ratio.
The auto version is something I've never used so I can't really comment on it other than to speculate that Ford is using their knowledge of the torque management programming to keep it in a range that's safe for the auto.
